Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
New iFixit battery installed, pressure on screen now
I just installed the ifixit iPhone 5s battery replacement with adhesive and now have an LCD rainbow along the center line. It shows up when pressing the home button and when tapping the lower half. The screen does not experience this effect when the LCD was removed and held away from the phone body with the connectors attached and powered on. I removed all the old adhesive. I attached the new adhesive. I went as far as pealing off the ifixit label on the battery and it helped just a little.
Update (04/30/2016)
The battery didn't change dimensions from when new, but after sitting overnight in the phone, the screen issues are a little better. Yesterday, it would rainbow on taping on the lower half, but today it rainbows on a direct hit. The battery install is one shot. If I were to remove the battery and reinstall, I'd need another battery because I'm sure I'd bend it.
Questa è una buona domanda?
Punteggio 3
2 Commenti
Have you tried pushing the battery down lower? Can you take a photo of the battery? Is the battery adhesive like the same as the previous one?
da
Does the battery appear swollen at all?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
I put to much focus on the new part going in my phone and not enough on the old parts going back. The metal bar over the battery connector became flipped. It has been reversed an all is fine now.
Punteggio 1
Since your order was recent, go ahead and call or email iFixit. They will gladly send you out a new one. It appears your battery is swelling and that is no bueno :(
Punteggio 0
Aggiungi la tua risposta
wolear sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 128
