iPhone 6 Touch ID Issue after Screen Replacement
So I replaced the screen with a part off eBay and followed ifixit to the letter. I have also transferred the metal contact plate from the frame.
The home button feature of the iPhone works fine, however the Touch ID function doesn't work at all, and when trying to set up just says failed try again. I have tried a hard reset.
Having looked around there are suggestions to replace the extension cable, however I do not see how this can work as the home button function still works.
I was extremely careful when removing the home button and don't think I damaged it at all, any advice? Something I might have missed?
Many thanks
Questa è una buona domanda?
2 Commenti
The extension cable may be damaged. This can happen especially when you lift up the sticky part at the bottom of the extension cable, where the home button plugs on top of.
da Ben
I'll try replacing that - surely however as the clicking function of the home button works Touch ID should work? Or is that not quite how it functions
da Lewis Watson
