Salta al contenuto principale
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
117 Domande Visualizza tutte
Samsung Galaxy Note 10.1 stuck in reboot cycle
plss fix this samsung galaxy note 10.1
Questa è una buona domanda?
Punteggio 1
2 Commenti
why i cant fix
da
it was stuck in reboot cycle plss fix
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Have you tried pushing the power and volume up buttons together or the power and the volume down to power down the device? If it is off you could then either try to start it normally or try to flash a new ROM onto the device.
Punteggio 1
I would take out the battery and then put the battery back in, but if it is an internal battery like an apple product you might have to get the battery to turn off fully until it will not even turn on then charge it and turn it on and hope for the best.
Punteggio 0
2 Commenti:
i try it but didnt work
da
You might have to reset to factory default to see if that fixes the reboot cycle.
da
Aggiungi la tua risposta
Adam Matthew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 363
