Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
Searching for network problem
hi every one
i have problem with my iPhone 6 i jest format it from settings
and after that the phone could't find a network ( searching )
i set the time on phone automatically and reset network settings
but it didn't work.
help me please
thank you
and sorry for my English
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
@oscarpants Dial *#06# and tell me if the IMEI is displayed when doing so. If not, you have a Baseband IC issue and would be a hardware repair reballing the IC with Microsoldering and running a couple jumpers to pads under IC.
Punteggio 1
Have you tried a restore through DFU mode?
Open iTunes and connect the iPhone to your Mac.
Press and hold the Home button and the Sleep/Wake button at the same time.
After exactly 10 seconds release the Sleep/Wake button.
Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
After that just click restore.
Punteggio 0
hi
I just got iPhone 6 and it keeps on searching I keep on restarting it but still keep searching I don't know whts wrong with it. please help me kim thanks
Punteggio 0
Try to perform a restore from recovery mode. https://support.apple.com/en-us/HT201263, this will put a fresh copy of the iOS on you device.
Note make a backup of your iPhone first.
When you set up it choose "set up as new and test."
Punteggio 0
Aggiungi la tua risposta
ali alhashimi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 396
