Phone shuts off upon any little movement or shakes
When phone is turn on, It shuts off when trying to slide it open. It also shuts off with any little movement or shake while holding the phone.
Questa è una buona domanda?
Trying checking the battery contacts or the metal clips that hold the battery inplace push them forward..using a pic on the battery contacts so that they are more in contact with power connecters on the board. I had the same problem til i did that ..ever since havent had that problem at all..
That works fine. I put a piece of wood after the battery. Works fine now. *shake* *shake* *shake* - yep ;-)
Just to add to the previous answer, I've fixed a similar problem by applying some Blu Tack on the battery - it never switched off ever again.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,444
