Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Screen assembly- is there differences between different iPhone 5?
Hello!
I was just working with my friends Iphone 5s. I was trying to change the screen assembly, and I think everything went well, but the solution was bad.
Now there is vertical stripe going across whole screen, and when trying the number buttons number 0 is not working.
I took the part from my home, so I don´t know if it was Iphone 5s or another Iphone 5 part. Is there differences between those?
Should I just open the whole thing and but it back (I mean if some of the flex is badly on) or should I change the part to an another?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
It sounds like you have either a damaged digitizer cable, or it is the wrong part. To answer your question, yes, the iPhone 5 display and the iPhone 5s display are different, and an iPhone 5 display will not work in an iPhone 5s. However, to me, your problem sounds more like a damaged digitizer cable. I would just get a new part. Hope this helps.
Punteggio 0
Aggiungi la tua risposta
aspi91 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 46
