Salta al contenuto principale
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 Domande Visualizza tutte
Nokia Lumia 920 not turning on
i also have the same problem and always do the same thing by press the volume and power on/off and its works usually. but now its not really work. there are no any response when the phones was charging. it looks died. the hard reset also cannot do anything. whats the problem??!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Connect the phone to a PC (be sure your cable is working).
Try to switch it on. If the PC recognizing your device 90% you have a SW problem. Try to restore the phone:
Windows 8/8.1 Windows 10 Boot Manager Error Solution
If your PC does not respond when you connect the device, then the problem is hardware, broken USB connector, logic board damage...
Regards.
Punteggio 2
1 Commento:
@zfix I referenced one of your you tube videos to help someone just now thanks for the video it was great
da
You try reset factory?
Punteggio 0
Aggiungi la tua risposta
caercspf sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 497
