How to fix error on my camara, error code 0xA00F424A(0xC00D3704)
Error code 0xA00F424A(0xC00D3704
Questa è una buona domanda?
1.) the camera is currently being used in another app
2.) your camera is updating
3.) shutdown and relog into your device
4.) exit out of all tabs and/or refresh
5.) reinstall your camera app
6.) don't use your camera at this time and try later
was this helpful? thank you for reading and i hope this was helpful.
Nothing works no matter what I do, I reset my phone to factory but its messed up still, :/ I may just take it to a shop
how to close the othar app
another one solutions for switch camera front to rear, press switch button and minimize the app and again go to app.. hope its work.... Thanks
I did it and it worked. Thanks
It worked for me too . Thanks
works for me. thanks
Man your a genius, ive been trying to fix this issue for years an yours is the only way to fix it lot of thanks to you
Each time I try to use my camera for front facing it says "something went wrong"
ad 1 - no, i;ve got clean install
ad 2 - no, I've got last updates installed (error occured even after clean factory reset)
ad 3 - no effect
ad 4 - no effect
ad 5 - I can't uninstall factory installed CAMERA app (error occurs on other apps from store, too)
ad 6 - great advice - I'll try on my next phone :)
Every time I tried to go to camera. It goes out and back to home sceen
My front camera is not working
Problem solved by service - changing mainboard was needed :( Nothing about software.
I have a Nokia Lumia 830 cell phone running Windows 10 Mobile Version: 1607, build 1480, firmware: 02040.00021.15235.53001, it has been a perfect device until now. Took a normal photo, tried to send via messaging, "Can't Send", tried sending a couple of times. Went to take another photo, with message "Something went wrong" If you need it, here's the error code: 0xC00D3704. Also noticed the flashlight app no longer works. Can't do anything with the camera app. I'm guessing this is a driver problem but have no way to correct, update or reset. HELP
This error comes as CAM is already in progress in different APPS.
check the processors in the task manager ,if any skype and any cam related applications are running then END TASK and check the camera hope it will start working
It looks like another app is using the camera already
please guys help me I have unrro camera
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 31,111
5 Commenti
please restart the computer then your camera will do the job
da Faiz Awan
ty very kind of you
da giugiulupu
no use of restarting: i have the same problem and i tried it but it doesn't work.
da Krishay Naik
Mi teléfono Microsoft Lumia 950 tenia ese problema y lo corregí cambiando la cámara frontal de otro teléfono dañado de la pantalla, fue la única forma.
da Roman Luevano Muñoz
This erro comes as CAM is already in progress in diff APPS.
check the processors in the task manager ,if any skype and any cam replated applications are running then END TASK and check the camera hope it will start working
da sarvan
