Salta al contenuto principale
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
White screens flash and then powers off..
So I have an Nintendo dsi XL and I replaced the power board and from that time i have the 2 screens that flash white and then power off..
I already tried to reconnect all connectors, but that didn't help...
Any ideas ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
UPDATE 2.0
It was the Fuse un the power board that caused all that trouble. In fact it was a fuse with resistance! So it powered off when it was underpowered! I just removed the fuse and it worked (replaced with a wire)!
I hope this will help somebody with the same problem!
Louis
Punteggio 0
1 Commento:
which fuse???
da
Risposta Più Utile
OK I FIGURED SOMETHING OUT !!!!!
When I push SELECT and VOLUME DOWN on boot it works BUT when I power it off on MAX brightness it doesn't power on anymore !!!! SO if I put the brightness just one step DOWN it WORKS !!
Still I would like to know what's causing that problem
Punteggio 1
Aggiungi la tua risposta
Louis de Looze sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 174
