Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
799 Domande Visualizza tutte
Why does my iPod say very low Battery?
So i have replaced the battery and the hard drive to a photo drive. My ipod wont hold a charge at all now and i dont know why or what the problem could be. it says "please wait very low battery" and it has been on charge for several hours. it showes a battery with a circle and a slash threw it.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi Mallory
Assuming that your new battery is good and is connected properly you may need to put your iPod into disk mode, https://support.apple.com/en-us/HT201544 , then connect it to a wall charger. This can sometimes fix this issue. If it doesn't you may want to double check the batteries connection just to make sure it is seated properly.
Punteggio 4
This also happened to me, I had not fully inserted the ribbon to the new memory.
Punteggio 0
Aggiungi la tua risposta
mallory sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 75
Tutti i Tempi: 19,002
