Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
I have iPhone 5S without PM8018
I buy iPhone 5S on ads....no IMEI or Modem firmware...not on iCloud. He restarts every 3min. Cant charge on power adapter but charge on PC. Fast recharging...tooo fast. I open front glass and saw than motherboard not have EMU shield and missing IC PM8018. My question: whether it is worth to change this IC or not? Thanks!
Update (04/14/2016)
Here is pictures before:
In service they replace PM8018 ic and now iPhone 5S is working fine (now IMEI and modem firmware is visible)... but TouchID not working (Home button woking fine). And now strange things is happening: iPhone only charged on PC not on Apple charger...and too fast draining battery when leave on night (DND mode, no notification). And only charge battery when PowerOff iPhone (when is PowerOn iPhone restatrt every 3min).
I suspect on charge connector on logic board or components around...
This iPhone (before I buy) is water damaged...
Probably water damage on board but I cant see where...
What do I looked on logic board? Which component?
p.s. In service they replace my logic board in other iPhone 5S case ....
Update (05/22/2016)
Here is 2 missing component near battery connector...
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If replacing the missing components doesnt fix the fast drain then check the usb ic, i think its 1610A2 or 1610A1
Punteggio 2
1 Commento:
Also fast battery drain can be caused by a short. Look for anything that causes excessive heat
da
Aggiungi la tua risposta
Zeljko sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,622
