Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
What to do with this issue after water damage.
So i literally dropped my phone in soapy water for like 1/4 a sec and now after putting in rice for 3 days it doesnt work or charge, I took it apart and where the screen receptors are I saw a lot of water residue, is there any way to get it back to work or will i have to buy a whole new logic board to replace it?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Unfortunately, because all of the logic board components are soldered together, you'll need to replace the entire logic board, whose guide is found here: [collegamento guida non valido]
Punteggio 0
I had a similar problem with my iphone 6. My phone was in a Lifeproof case and I walked in the pool with the phone in my pocket. After 20 minutes in the water I noticed that there was a bit of water in the case. I immediately turned off the phone and dryed it out with a hair dryer for about 30 minutes. The phone turned on and turned itself off. It never turned on again or charged the battery at all.
I replaced the LC/ Headphone Jack module, but that did not fix it. Then I carefully looked at all the connectors using a 16X jewelers lupe and found the home button module connector was oxidized. I cleaned the connector with 91% isopropyl alcohol using a cotton swab, and a small nylon bristle brush. I assembled the phone and when I powered up the phone... and voila! It worked just fine!!!
Punteggio 0
Aggiungi la tua risposta
hyrqBot sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 108
