iMac not reading hard drive
My imac hard drive failed and i had to replace it. Once i replaced it the imac booted up fine and i started an install and it said installation could not be verified so i got a different copy of osx 10.9 but when i booted up the imac it would not read the hard drive. I thought the drive went bad but when i removed it and tested it on another system it worked just fine so i reinstalled it but nothing . Screen just showed a folder with question mark flashing and when i tried to install an os it started to mount and when installing i got a circle with a slash through it.
Questa è una buona domanda?
5 Commenti
Can you give us the make and model of the HD you are trying to put in.
da Dan
Your systems Specs: iMac 20" 2.4 GHz Core 2 Duo
da Dan
yes i did format the hard drive. the mac even read it at first
da john blaine
imac 20" 2.4 GHz Core 2 Duo, Seagate Barracuda 7200 320gb
model:ST3320620AS
da john blaine
Your Seagate drive specs: Barracuda ST3320620AS
da Dan
