dont want to turn on. only red light
My mac pro late 2013 does not want to turn on. when i remove the casing and plug the power cord the only thing that turns on is a red light
Questa è una buona domanda?
So far we've not encountered any problems with our Mac Pro's so I can't offer a sure thing here. The things I look at across the board is if the system was plugged into a good surge suppressor or UPS unit.
Next knowing some of the symptoms or issues that preceded. Sometimes this offers a clue on where to look.
Did you try checking the connections to see if any are loose here?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,350
6 Commenti
Same thing happened with me today. New Mac Pro suddenly doesn't turn on?
Yesterday it was working normal and nothing happened to it. Today it doesn't turn on anymore, still seeing the back ports light from HDMI blinking sometimes when i try to turn on.
Any ideas ?
Please help.
Recently using El Capitain 10.11.04
da enki nyxx
Ya, same here Mac Pro wont turn on .
da monserate colon
Any solutions for this problem?
I just got my hands on a machine with the same issue. I do not know the history of this machine and am pretty confused as to whats going on, and cant seem to find a thing online regarding this issue.
Please let me know if you have found a solution, and if not could you explain the behavior of the machine before this occurred?
Thanks!
da Taylor Struna
Everyone is looking for an answer without doing the diagnostics! Are you up to it?
da Dan
The Mac Pro has a total of 12 diagnostic LEDs. It would be helpful if you try specify where the red light came on or try to take a picture of it.
da Carsten Vollrath
Mostra 1 altro commento
