Salta al contenuto principale
Home security system with 24/7 surveillance capabilities released 2015. Identified by model number NC1102ES
Why won't the Nest Cam stay on?
I have the camera set up, and the app is working with the camera. However, the camera will not remain on for more than three minutes or so. What am I doing wrong?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
The Nest Cam works best when it is plugged in continuously, ensure that your Nest Cam is in a spot where the power cord can be connected at all times. Refer to our Troubleshooting page for more assistance.
Punteggio 0
Which Nest Cam do you own? I've had a similar problem with Nest Cam Indoor and Arlo Q security cameras. I solved it by contacting the support team. It might help you solve it too.
Punteggio 0
Which one camera you are using? I think it is working now.
Punteggio 0
Aggiungi la tua risposta
Lisa Langley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,429
