Salta al contenuto principale
Released May, 2013. Display - 1200 x 1920 pixels, 10.1 inches. Chipset - Qualcomm Snapdragon APQ8064, CPU - Quad-core 1.5 GHz Krait, GPU - Adreno 320. Memory - 16/32 GB, 2 GB RAM. Android OS, v4.1.2 (Jelly Bean), upgradаble to v4.4.2 (KitKat).
Disassembled part - where does it belong to?
Hi there,
I got a disassembled XZ Tablet.
However, I`m clueless about one last part. It has a white adhesive tape on the back.
Does anyone know where this piece of plastic goes to?
Thanks in advance.
Peter
Questa è una buona domanda?
Punteggio -1
2 Commenti:
That is a light pipe. It goes against an led. Soooo helpful right? :P It's not important. If you notice one of the lights on the front is dimmer, then it goes there.
da
In some cases you might not even see the LED without that on.
da
Aggiungi un commento
1 Risposta
after putting it together and turning it on the led went on, right above the volume rocker...well, there´s the right place for this piece. Thanks @ Josiah Crook and @ Ben for your help. Without it I´d not know what the piece is good for.
Punteggio 0
Aggiungi la tua risposta
Peter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 138
