Phone Not restarting after reset button press
Pressed the reset button and the phone is hanging with the the sign samsung only showing
Questa è una buona domanda?
So you did a factory reset through the phone's setting right? You should still be able to break out of bootloop without reloading the system software on the phone.
Disclaimer: You will lose all data in your internal storage on the phone if you follow the steps below.
Steps to Factory Reset most (if not all) Samsung phones:
Now your device should come out of the Android Boot Loop and at the first time the device will take some time to reboot.
If these steps still don't work then you may need to restore the software on your phone via Samsung Kies. If I can remember you do it via Tools > Firmware upgrade and initialization. This will prompt you to enter the model number and the serial number of the phone which is usually at the back of the phone or in the battery compartment.
If the Samsung Kies method does not allow you to download the firmware for your phone then you'll have to go to http://www.sammobile.com/firmwares/ where you type your model number of your phone to find the firmware for your phone. Make sure you choose latest version to the network it was mainly with.
Samfirmware instructions (After the file has finished downloading):
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 64
