Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2201 Domande Visualizza tutte
battery dies at 50%
I purchased a new battery from you guys and installed it. When I installed it it was dead. Pluged it in and it took 30min for it to turn on, Let it charge till it was completely charged,. Now when it gets to 50% it shuts off saying battery dead. Did I get a bad battery
Questa è una buona domanda?
Punteggio 1
1 Commento
ag ana dndn ansnf
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
You could have gotten a bad battery. This is one symptom.
Contact sales@ifixit.com and tell them about your problem.
Punteggio 2
Did you put the battery grounding clip back on under the battery clip? Because if you don't have it on, you may have a issue like this.
Exact battery ground clip installation, iPhone 4s?
Punteggio 1
bad battery certainly
Punteggio 1
New batteries have never been charged so you set the life of that battery with the first 3-4 complete charge/discharge cycles that every seller recommend to do. You should let the battery charge with the phone off for 10-12 hours for these cycles then you can use it as you want. It makes a big difference, that's why I think that the battery you have is acting like this. If after making it charge and discharge like this it keeps working bad you probably have a bad battery.
Punteggio 1
Aggiungi la tua risposta
tammy barlock sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 337
