Salta al contenuto principale
The AmazonBasics BTV1 is a portable Bluetooth speaker that also includes a microphone for conference calls.
Why isn't my phone pairing with the speaker?
When I enable the Bluetooth on my iPhone it still doesn't pair with the speaker. I tried turning it off and then back on but it still doesn't work. How can I fix this?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The first thing that I would recommend doing is checking to make sure that the device that you are connecting with is compatible with the AmazonBasics Bluetooth speaker device that you are connecting to. Once you have checked compatibility, make sure that you are with in the specified range for the device to remain connected to the speaker. If the issue is still not resolved check the trouble shooting link for other possible solutions. Good luck! AmazonBasics BTV1 Troubleshooting
Punteggio 1
Aggiungi la tua risposta
Chris Shannon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 430
