Why my half of the screen turn pink in color
half of my screen turned into pink and blur.
Questa è una buona domanda?
Rajesh Adapa connect an external monitor and see what that shows. If it is working good than you most likely have a bad LCD. If an external monitor displays the same errors, you are having issues with the GPU circuitry on your logicboard.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,998
1 Commento
What is the history of this laptop? Have you dropped it or damaged the hinges on it?
This can either be a faulty screen or bad connection between the LCD plug and the LCD (Not plugged in fully or correctly).
It can be other things that I don't know of as well.
da Ben
