First time attempting screen replacement
Hi Guys.
OK my first time attempting replacing the glass on a 42mm Apple Watch Sport.
I have successfully removed the LCD assembly but i seem to have damaged one of the flex cables attached to the digitiser connectors its the flex which is soldered to 3 points on the main digitiser connector next to the digitiser chip.
I have read a couple of reply's on other threads i'm just trying to understand the terminology used & identify the damaged part.
It was mentioned in another thread that you cannot separate the glass from the LCD without damaging the force flex sensor i'm just wondering where the force flex sensor is i have contacted some suppliers in china & they say the part i have damaged is the IC.
I'm hoping someone can clean this up i'm going to add some images
Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
