Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Bsod during dfu restoration mode
After putting a new screen on my 5s it kept showing the bsod so I decided to try to restore the phone but about 8 seconds after the progress bar not moving it shows the bsod and then gos back into dfu mode! And on the computer it shows that "error 9" is the problem but I changed the port that I was using to a different one on it and bought a new cable and tried it but still shows "error 9"
Any advice?
Andrew
Questa è una buona domanda?
Punteggio 0
1 Commento
This is probably due to the band chip being corrupt / faulty on the logic board. In most cases not worth repairing.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Go to step 11 of this guide and compare the screw placement to the screws that you put back after the screen replacement.
If you mixed them up, you could have caused long screw damage.
To rule out other things, try to do a DFU restore (google it) with the front camera cable unplugged. What happens?
Punteggio 1
3 Commenti:
The screws were good and I followed the dfu restore but during the restore it dose the bsod and then reboots
da
Last thing you can try is a known good battery and try DFU restore after that.
da
I’ve seems defective screens do this, however unlikely. If that doesn’t work it could be a logic board issue.
da
Aggiungi la tua risposta
Andrew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 86
