Salta al contenuto principale
Where can I get a replacement screen
bugs are eating my screen. where can i get a replacement screen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@saillll it will be pretty close to impossible that you will find a replacement screen. It will cost more than a complete new TV. I suggest that you try and find your model TV that has other issues and is no longer working but has a good LCD. Than use that one to harvest the LCD screen from it. Explain the bugs eating your screen a bit more. Never heard of that,
Punteggio 4
You might want to check EBay, or Craigslist for a used TV like yours. If you can find a working model, I would keep it as the working TV' and strip your current set for spare parts. It would probably be cheaper and less time consuming then changing the screen.
Punteggio 0
Aggiungi la tua risposta
mitch morrison sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 327
