Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
iPhone 4s does not start, it stays at the apple screen
Phone started malfunctioning, battery was draining quick, and it will turn off. sometimes it will let it charge, some other times it will not. got to charge it a few times. This one time, it stopped showing me if it was charging. the apple icon comes up, it stays for 1 minute or 2 and then the phone goes dark. I assumed it was the battery or the port, maybe poor connection.
So, I replaced the Battery, and power port. but the same thing, the apple logo comes up for a few minutes, and it goes dark (off). tried to do hard resets, erasing the phone thru the iCloud service, NOTHING... I am running out of options.... any other suggestions?? it will be appreciated.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try reset the phone with iTunes. When the phone is off press and hold home button and plug the USB in the computer and the phone. Hold the home button until you see the iTunes logo saying connect to iTunes, then iTunes will recognize the phone in recovery mode and just press restore.
Let me know if this help
Good luck
Punteggio 0
2 Commenti:
It did not work, unfortunately..
da
If this didn't work try like Mo said new battery. Let us know
da
Risposta Più Utile
Try using a new battery. Sometimes when the batteries are old and mis-used, they get shorted out. And normally a new battery fixes it. Hope it works, good luck.
Punteggio 1
Aggiungi la tua risposta
jhonnyt16 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 52
