Salta al contenuto principale
Il Sony Xperia Z3 è uno smartphone Android lanciato nel 2014 noto per la notevole durata e autonomia della batteria.
114 Domande Visualizza tutte
No Mobile Data Connection
on a network compatible with my factory unlocked gsm device, apn setting are correct, no sim card errors, phone recognizes the network, but even when i do have service bars i cant call, it doesnt ring or dial out it just hangs up saying mobile network unavailable, cant send/receive texts, and cant get in the internet without wifi. my IMEI is not blocked and the software repair with sony xperia care didnt work on resolving the issue
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Are you running currently with 4G enabled? When you do calls it switches to 3G in order to connect the call.
Anyway inside the phone there is an antenna cable which can get disconnected if you've dropped the phone, also the antenna cover will probably need to be realigned by unscrewing the to screws at the bottom of the phone. You'll need to push the antenna cover down so that it has full contact with the antenna pins before you screw it back in.
Check out the z3 ifixit guide to remove the back cover.
Punteggio 2
Aggiungi la tua risposta
Cliffton Thyarion sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,842
