Salta al contenuto principale
Repair guides and support for Kenmore washing machines.
Washer will not fill when in sensing mode
I have a brand new Kenmore series 100 top load. Did everything by the instructions, but when I turn it on it just buzzes in "sensing/fill" mode. No water comes into the machine. Yes there is water getting to the machine as I did a test on the "delicate" setting w/o clothes just to try it and rinse it out. Now nothing.
I bought this for my wife in December for the apartment being renovated for us, and we just moved in, thus it is really a brand new machine.
Questa è una buona domanda?
Punteggio 2
1 Commento
washer wont sense load size, only fills water alittle
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Parts
Cause 2
Low Water Pressure from House Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
Punteggio 3
1 Commento:
washer only fills high on soak. checked everything out and only fills low on other cycles even though i chose med or high. checked the tube and pressure all good. could it be the sensor gone bad?
da
Aggiungi la tua risposta
catskillcounselor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 16,984
