Why is my tablet not charging?
I plug my tablet in and it doesn't charge at all, why is that happening and how do I fix it?
Questa è una buona domanda?
The Nabi tablets I have fixed for charging are the charging port on the tablet. The solder joints have most likely come free of the circuit board and need to be replaced. You will want to check the charger for proper output voltage before opening the tablet and checking the charging port.
Do you know where I could find a charging port for the Nabi 2S?
The charging port for the tablet will be a round hole on the tablet and will have a metal post that protrudes from the center of that hole.
@dohboy thats for the original nabi 2, the nabi 2S used the dream tabs charging port.
If your having trouble charging your tablet, there might be a problem with the charger itself. If you have tried a new charger and the problems persist, I would suggest replacing the battery on the tablet. Please refer to our troubleshooting page for more help!
mine has the same problem but it might either be the battery or the charging system itself. there have been reports of nabi 2s tablets refusing to charge after some time. try replacing the battery. if that doesn't work then you might need to solder on a new charging port... might I suggest you solder on a USB Type C port instead of the official nabi port?
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 884
