Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone is searching for network
My iphone 5 today suddenly started started searching network,
I took out the SIM card , it still kept searching for network instead of saying no sim or no service.
I reset network settings, then all settings, turned phone on off several times, put back sim in, hard reset it etc.
I haven't restored it from itunes that I will do next but I am wondering if any one had simlar problem.
Taking SIM card out should changed it to no sim or no service but it doesn't do that so that is weird.
Another thing is it doesn't give me an option to select carrier manually as that option has disappeared from the settings.
Please help
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Do you still have an IMEI number displayed in the Settings > General > About Phone? (Don't post the IMEI number here as it uniquely identifies your phone)
da
whaaaat the !&&*, I cant find it O_o
da
Aggiungi un commento
2 Risposte
This can happen if the time/date is set wrong. Try manually setting the time, pop the SIM card in. If that connects to network change the time setting back to Auto.
Punteggio 0
1 Commento:
The date is correct:/
da
There are too ways to solve it.
Method 1(you already tried):
Try Reseting Network Settings by going into
Settings>General>Reset>Reset Network Settings
Your phone will restart deleting wifi passwords and so on.
Method 2:
If it's a hardware problem then the only solution is to heat the baseband ic (under sim tray) with a hairdryer for approximetely 5 mins
According to iPhone could not be restored unknown error 1
Do not try to Restore phone via itunes cause your phone will be unusable (happened to me)
Post back with the results
Punteggio 0
3 Commenti:
So what will happened if I would heat it? He did not get wet :/
da
well, nothing happend
da
You can find your IMEI on the settings? If you can't then it's hardware problem
da
Aggiungi la tua risposta
David Jan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 244
