Salta al contenuto principale
Can't bootup..stuck grey screen
I could go to openfirmware mode, and also I could use mac os 10.5 CDs to proceed to a certain point where "cannot be installed on this computer" comes up... at this point, I could use disk utility to at least see my HD model/serial number, but it says not mounted.
So my question is,
based on the above symptom, what's the likelihood of this being a logic board failure?
(I'm asking this question because I've tried swapping to a new hard drive and the same "cannot be installed.." message came up).
If diskutility at least identifies my HD, is my logic board OK?
Thanks in advance for any advice.
-genius bar sucks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Format the hard drive with disk utility. Now install the system.
Punteggio 2
1 Commento:
Aggiungi la tua risposta
Albert Kim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 885
