Salta al contenuto principale
The Samsung NX2000 is a digital smart camera with a detachable external flash that was released in late 2013.
Why is my flash not working?
No flash is being produced even when I try to turn the camera on and off.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
A simple solution to your question will be that you have to first turn off the camera and then proceed to remove the battery and memory card from the camera's hardware. After waiting a few seconds, reinsert both components and restart your camera and then make sure your camera is set to Auto Mode. Press on the shutter button to ensure your flash is producing a flash. If it is not, then you may need to charge the battery to your camera.
Hope it helps
Punteggio 0
Aggiungi la tua risposta
Katarina Raic sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,802
