Salta al contenuto principale
The Samsung Galaxy Alpha smartphone was released in September of 2014 and is also known as the Samsung Galaxy Alfa. It runs on the Android operating system and is carried by most major cellular providers.
How do I fix the black screen?
I dropped it on a hard surface with the screen protector on , it powered up ,the volume buttons work and notification sounds are on but the screen remained black. How can I fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like you broke the LCD. If you are sure the Device still turns on then the LCD is likely to be damaged.
You would need to replace the screen there is a guide on how you can replace that phone Samsung Galaxy Alpha Display Assembly Replacement
Punteggio 1
Aggiungi la tua risposta
madastfleur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,354
