Salta al contenuto principale
Portable wireless speaker with a built in microphone. Released January 27th, 2014.
36 Domande Visualizza tutte
Why is my device not charging?
I connect my device to the USB cable and never charges unless I hold the cable.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
6 Risposte
Risposta Più Utile
Hi Daniel,
This problem sounds like you have a faulty MicroUSB port on your Flip 2. On occasion, the Flip 2's MicroUSB port may become dislodged, causing issues in charging or connectivity. You can try soldering the MicroUSB port back onto the circuit board. You can visit our guide here for more information on the repair of the port.
Punteggio 3
it sounds like the charge port is broken if it needs to be in a certain position to work
Punteggio 1
I charge my flip 2 & it doesn't charge.
Update (04/27/2017)
Yes I have to position it a certain way but still don't get full charge & how much would it cost me to get this repaired and where can I go.
Punteggio 0
2 Commenti:
Hi Veronica,
Did you solve the problem already and if yes, diy or specialist repair? I have the same problem.
Erwin
da
I am experiencing the same problem with my speaker in that it wont charge. If you fiddle with the cable the lights will flash briefly and then goes off. How can this be fixed as I like the quality of the speaker. Assistsnce will be appreciated.
da
JBL speaker charging soket damage
Punteggio 0
I have had that problem over the past decade with various Bluetooth speakers & headphones that require recharging. I find that the manufacture of the recharge ports and cords is anything but standard. By hanging onto every charger cord I get with products and any that someone has thrown away (and buying a few for less than $10), I usually find a charger that will work for any particular item.
Punteggio 0
Punteggio 0
Aggiungi la tua risposta
Daniel Anzola Delgado sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,574
