Salta al contenuto principale
i need help replacing my display
Hi. While i was trying to replace my lcd i accidently took off the silver part that has the orange sticker on it and is supposed to help you take out the lcd. Now i cant take the lcd out.
Can anyone help find another way to take it out?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Tweezers are your best bet, I've done that before and after you get the silver part off the display can be tricky. It's not that hard to pull out however, so as long as you don't put too much pressure on it, go with tweezers.
Punteggio 0
U have to be a little more specific before u get an accurate answer. What silver piece? A word of advice, a display replacement is difficult and requires a ton of patience. It can be done, but u have to have.
Punteggio 0
Aggiungi la tua risposta
conker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 771
