Salta al contenuto principale
The Nikon Coolpix S33 Waterproof Digital Camera B00T85PKD0 is designed as an all purpose camera that is waterproof, shockproof, and freeze-proof.
17 Domande Visualizza tutte
Why won't my Nikon Coolpix S33 turn on?
My camera will not turn on. I'm not sure if it is a battery problem or something else.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Hey,
You are going to want to make sure that the battery is inserted properly into the device, the best way to check this is to see if the battery cap is clicked in properly. If this is not the case, then you might have a drained battery and should charge the device without any interruptions.
If the two solutions above have not worked, check the following page for more possible problems that could be causing your camera to not turn on and their solution:
Nikon Coolpix S33 Troubleshooting
Punteggio 0
The battery is no good or its not charged.
Punteggio 0
Aggiungi la tua risposta
Kacie Lemos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 4,875
