Salta al contenuto principale
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
280 Domande Visualizza tutte
Wondering if it's a bad relay switch...?
found a tx-v940 at goodwill. same problem - no power to speakers. Did randomly come on at times, but when powered off then on again, there's nothing at the speakers again. Also a series of clicking noises, like some component is powering on/off. Wondering if it's a bad relay switch....?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Rich Plotner,
Receivers usually use relays to provide speaker protection in the case of a fault on the output of a channel (also used to prevent the speakers from catching fire if due to a fault there was excessive current flow to the speaker). it sounds like one or more are operating.
Here is a link to the service manual for a Onkyo TX-V940. It has all the information, e.g. circuit diagrams etc, to help you to find the problem.
http://diagramas.diagramasde.com/audio/O...
Punteggio 1
Aggiungi la tua risposta
Rich Plotner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,274
