Salta al contenuto principale
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Why is audio jack not working
Stop working completely wondering what to do and if a parts needs replacing where would I find it tried cleaning it out and restarted phone
Any help is fine thank you
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
First make sure all of the lint is cleaned out. Sometimes it can be really packed in there. I recommend curved tip fine point tweezers. if that doesnt work you will most likely need to replace it. you can find them on ebay but i believe it is soldered directly to the logic board making it a risky repair.
http://www.ebay.com/itm/4-X-Audio-Jack-H...
Punteggio 0
Aggiungi la tua risposta
Andrew Abbott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 26
Tutti i Tempi: 181
