Salta al contenuto principale
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
18 Domande Visualizza tutte
Can the hard drive be upgraded?
Can I upgrade the hard drive in my Asus Chromebook C201?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sadly, you can not upgrade the hard drive in the traditional sense. In fact, this Chromebook does not even have a hard drive installed. It uses something called an eMMC. This is a flash storage card that is soldered onto the motherboard. It’s similar in size and shape to an SD card, but is closer in function to a solid state drive.
While the eMMC in the Chromebook is only 16gb, you can offset the small storage capacity by using Google Drive. The Asus Chromebook C201 comes with 100GB of free cloud storage for 2 years.
Punteggio 4
3 Commenti:
This Chromebook also has a micro SD slot that can be used as a local hard drive for up to 128 gigs of storage.
da
No, but it can be used for storage.
da
I wanted to explain Ammar Rauf's post and Bryan's a little more. The eMMCcard can be desoldered, and there are 32 and 64GB eMMCs, if you can find out which ones are compatible. LabOne is in Pakistan, so shipping your Chromebook there might be a tiny bit expensive.
da
Now you can upgrade all the Chromebook storage up to 64gb
https://www.laboneinside.com/we-can-upgr...
Punteggio 1
Aggiungi la tua risposta
Robert Lawson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 14
Tutti i Tempi: 17,656
