Salta al contenuto principale
Phone unable to boot up nor into recovery mode
My GT-I9060I DS is unable to boot up completely and just hangs on the Samsung screen with a red exclamation mark in the top left hand corner. Also I am unable to boot it up into recover mode, it also hangs on the same screen mentioned above. It does however boot into Download mode but unfortunately there seems to be a problem with the usb drivers as Windows picks up device that reports and error, doesn't recognise the device despite installing and reinstalling all the drivers I could possibly find. Please help me recover my phone if there is a solution out there? Thank you
Questa è una buona domanda?
Punteggio 1
1 Commento
did u find any solution???
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Check the charger port for any blockage, is there any dust or blockage? If yes, use a tooth pick to clean it up. Then try download mode again.
Have you tried using samsung kies?
Punteggio 3
1 Commento:
try spd flash tool and drivers might help http://spdflashtool.com/download/spd-fla...
da
Samsung Recoveryis a good program which can be used to recover deleted contacts, text message, photos ,muisc and videos from all kinds of Samsung device, including Galaxy S5, Samsung Note 5/4, Galaxy S7, Galaxy S6, Samsung Galaxy Note and so on.
Punteggio 0
same problem. I can not go in recovery mode
I can only go in download mode. with Odin always the result Fail :(
can not install TWRP, CWM, etc
my English is bad :(
solution with spdflash tool, I need stok rom in .PAC for GT-I9060I/DS......Samsung GT-I9060i Grand Neo Duos
I have only frimware in .TAR and .MD5
thanks for help
Punteggio 0
change the charger usb port in your phone only
Punteggio 0
Aggiungi la tua risposta
Sebastian Fisher sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,394
