Salta al contenuto principale
Sony’s 20.1 megapixel camera designed to capture still images and video recording. Model number: DSC-W800.
11 Domande Visualizza tutte
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
Questa è una buona domanda?
Punteggio 1
2 Commenti
يرجى توضيح أكثر هذا قليلا
da
@tcampo what happens when you do replace the batteries? does it then turn on?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
Punteggio 3
Aggiungi la tua risposta
Thomas Campo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,254
