Salta al contenuto principale
The Hisense Chromebook C11 is a 16 GB Chromebook with 2 GB of RAM, produced by Hisense.
8 Domande Visualizza tutte
Hisense Chromebook c11 Chrome OS is missing or damaged
I try to reboot my Hisense Chromebook c11 when I hit esc, refresh, and power, it says "Chrome OS is missing or damaged. Pleas insert a recovery USB stick or SD card. " When I hit tab, it also says 0x02 recovery button pressed. To reboot I hit ctrl D and i hit enter, I hit tab again and it says 0x00 / 0x00 recovery not requested. After it beeps twice it goes black and wont turn back on again until I hit esc, refresh, and power again. If anyone knows whats happening please tell me.
Questa è una buona domanda?
Punteggio 9
1 Commento
My grandson had his for 2 months and his did this. I do the same as the comment above and it goes through until it finally says press SPACE and it will reboot but it never reboots. It goes black again and shuts off. Best Buy wants $300 to fix it. It cost $169. Really? It's not worth it especially since he only had it 2 months before it stopped working.
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
You need to download the Chrome Recovery Utility app on another working computer with the Chrome browser (this can be a Windows or Mac, doesn't matter as long as it's Chrome). You can find it in the Chrome app store. If you don't have another computer, ask a friend.
Then you'll need a SD card and reader, or a thumbdrive. DO NOT USE SANDISK BRAND. They do not work. (I know, because I tried and had to go buy a different brand of thumbdisk. Don't know why, but Sandisk does not work with Chrome Recovery Utility).
On the working computer, open up the app in Chrome, and follow the on-screen instructions. You'll need your Chromebook's serial number to set up the recovery disk. Your Chromebook should display it as a part of the error message. One the disk is prepared, you'll need to insert the disk into your Chromebook, and let it do it's thing.
I LITERALLY just had this happen to me on Tuesday this week (7.8.16) with my Hisense Chromebook, so I know this works. I've had mine for a year and it's developed a glitchy battery. Think this caused an improper shutdown and a memory issue to occur, resulting in the OS error.
Good luck!
Punteggio 3
1 Commento:
rachelfinder what thumbdrive did you use?
I've tried 3 and none of them work.
da
you’r os is missing or damaged
Punteggio 1
Update (09/16/2018)
Punteggio 1
1 Commento:
da
How would I do this from Android phone I don't have other lab top
Punteggio 0
Aggiungi la tua risposta
Jesse Perry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 5,977
