RAM upgrade for iMac mid 2011
Hi, I want to upgrade the RAM.
Can I put a 8 GB RAM Chip or do I have to put 2 units of 4 GB each? Thanks.
Questa è una buona domanda?
Yes, you can use 8GB memory modules in your system. In fact with the latest firmware on your system you can populate your system to a max of 32GB of RAM using four 8 GB modules. I do recommend using matched pairs when ever possible. In this case two 8 GB modules would be better than buying just one as later on you would need to replace it with a newer unit to match the second for the bank. You could have different pairs each a matched pair across the different banks.
Yes you can I would recommend crucial.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 828
1 Commento
Your systems specs: iMac 21.5" 2.5GHz i5 (Mid-2011)
da Dan
