trackpad button stuck
Hi,
My trackpad button is stuck down. Is this fixable, or must it be replaced? Can I try to pry it up, or will I risk breaking it? Should I take the topcase off and investigate first?
Thanks...
Questa è una buona domanda?
Hi,
Thanks...
Hello!
The danger with prying it up is that you can create small burrs in the plastic that further rub and hinder trackpad button use. I would investigate by removing the upper case, as you mentioned (especially because the removal is an easy one)!
I hope this helps!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,277
