Salta al contenuto principale
Repair and disassembly guides for GE Microwave ovens.
replace surface light bulbs
How do I replace the surface light bulbs on my G E microwave model JVM1631BJ03?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@bobbbbbb Not exactly sure which light bulbs you need. From your brief description it sounds like you are talking about the cooktop lights:
Cook top light incandescent bulb WB36X10003
To replace the bulb(s), first disconnect the power at the main fuse, or circuit breaker panel or pull the plug.
Remove the screw at the front of the light cover and lower the cover.
Be sure the bulb(s) to be replaced are cool before removing. After breaking the adhesive seal, remove the bulb by gently turning.Replace with the same size and type bulb.
Raise the light shield and replace the screw. Connect electrical power to the oven.
Oven Light Incandescent bulb WB36X10198
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grill by taking out the 2 screws that hold it in place
Remove the charcoal filter (if present) to access the light cover.
Remove the light cover located near the center of the oven that holds the bulb. Remove the bulb by gently turning. Replace with the same size bulb.
Replace the light cover and charcoal filter (if present)
Replace the grille and screws Connect electrical power to the oven.
Punteggio 2
1 Commento:
What??? "After breaking the adhesive seal" where is this? We are renting and Have a bulb stuck. Not sure if there is an adhesive seal on it or it's just stuck....sigh...
da
Try this: LED Surface Light Replacement.
They are LED, so should last much longer - probably longer than your microwave.
https://www.youtube.com/watch?v=iexGoo3R...
Punteggio 0
Aggiungi la tua risposta
Robb Wolfley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 7,520
