Salta al contenuto principale
Released in April 2012 by Garmin. The Garmin Nuvi 2595LMT has a 5" (12.7cm) touchscreen and voice-activated navigation.
10 Domande Visualizza tutte
How do I remove the Digitizer from the LCD Screen?
I have a broken digitizer on my Garmin Nuvi and when I follow the disassembly guide, I can't figure out how to separate the digitizer from the LCD Screen. There aren't any screws, so how would I remove it? Can I even remove it?
Questa è una buona domanda?
Punteggio 3
1 Commento:
It works but the screen needs replaced do you have a screen?
da
Aggiungi un commento
1 Risposta
Hi Taylor, that is a great question. We have a digitizer replacement guide available here.
To answer your question, you need to use a metal spudger from the Ifixit Pro Tech Toolkit or other flat headed tool to gently pry the sides of the digitizer until it lifts open and separates from the LCD Screen.
I hope this helps you with your project.
- Mary
Punteggio 0
Aggiungi la tua risposta
Taylor DeWitt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 489
