Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
Earpiece,receiver not working on iPhone :/
My ear speaker stop working after I decide to get replace apple logo for led up one.I damage the battery flex cable but I did replace it with new battery,right now my only problem ear speaker not working.I can't hear anyone who is call me,only on speaker or with headphones I could hear.I don't know where is possibility to damage ear speaker just to replace the battery and apple logo,maybe some how I did damage flex cable that's connect to ear speaker (reciver) but I don't know which one,guys help figure it out what I need to replace.I don't think there is problem with earpiece.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi Daniiel
Most likely won't be the actual earpiece, they don't brake to easy. I will assume that you have damage the proximity cable, so change this one and see if it is going to work.
Hope this help
Punteggio 1
Yes seems like,it's flex cable which is for front camera and censor as well.Will replace and hope it will gonna work :)
Punteggio 0
3 Commenti:
Good luck hope it will work after the replacement. Please if it works mark my answer as chosen solution. Thanks
da
I have the same issue actually. Did replacing that flex cable fix the problem? I also changed the led light mod and I believe it shorts out the front facing camera flex cable causing both the camera and ear piece to stop working
da
Yes it did fix the problem.I actually damage this flex cable again and that time my front,back camera and flashlight and earpiece stop worked but I did replace it again and everything back to normal.It very important to be careful with that flex cable when u open up IPhone :)
da
Aggiungi la tua risposta
Daniiel Tsykhorskyi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,365
