Salta al contenuto principale
Both fan not working
Hi all
my old macbook pro has this problem. Both fan are at 0 rpm. I checked both and are not malfunctions... seems to be a problem with the SMC.
Important note: actually the MBP is working WITHOUT battery.
Question: use the laptop without the battery may affect the normal operation of the SMC and then keep the fans switched off?
Should I order a battery replacement for fix this?
Thank you
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Boot up from original system installation dvd, see if fans are running to eliminate possible software issue.
Punteggio 3
3 Commenti:
Thanks for accepting my answer. Please tell us your result in case this question comes up for someone else.
da
Fan not working anyway not even after resetting SMC...
I remember that the fans have always worked until I broke down the battery. Since I removed it, the fans have stopped working. I've ordered a new battery... I'll try to reset SMC after installed and charged it...
da
Please don't accept an answer till you have a solution because we stop looking at accepted answers questions.
da
First I would do a SMC reset. Follow this Apple T/N: Resetting the System Management Controller (SMC) on your Mac.
SMC has a few different functions. So while it manages battery charging and battery power management. This part of SMC does not involve the temperature management side of things.
I do strongly recommend putting the battery back in (replacing it) only because when you don't have it present it doesn't take much to pull out or cause a power disconnect from the power adapter. The way the system was designed the battery would fill in the power disruption. Think of it this way your laptop has a built in UPS!
Punteggio 1
Aggiungi la tua risposta
mbonomi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,639
