Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Stuck in recovery mode will not boot
Here is the problem:
-iPhone will not boot or turn on like its supposed to after drop
-Apple logo flashes for 1-2 seconds and screen goes black ( but phone is on)
-Phone is stuck in recovery mode
Events that lead to problem:
I dropped my phone this morning. When i picked it up the phone was off. I went inside to put it to charge for a few mins then i noticed that when i turned the phone on, the apple logo will flash for 1-2 seconds and the screen will go black. When i removed it from the charger, the phone would go completely off.
Here's what i've done:
I opened the device and noticed that the battery connector had gotten disconnected as well as the vibrator motor had came loose.
I reconnected the battery and vibrator motor and tried to start the phone. The phone still would not boot. Apple logo flashes 1-2 seconds, then screen goes black.
-i've tried replacing the battery with one that was in a working iphone. Same results
-ive tried changing the screen with a working one. Same results
-i've tried holding the home and power button. Same results
*I get "There is a problem with iphone "iphone" that requires it to be updated or restored" message when i plug the phone to itunes.
*Error 27 when i try to update the phone
Any ideas?
Could the phone have gotten wiped when it dropped and disconnected from the battery?
Is trying to restore the phone my only option?
Thanks in advance.
Questa è una buona domanda?
Punteggio -1
1 Commento
@oldturkey03 any ideas brother?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi Jose
It sound like you have hardware problem from dropping the phone. I think even if you try restore it won't work, but you can give it a go. While the phone is off hold the home button and plug into computer, hold the home button until you see on the screen of your phone connect to iTunes sign. If you get through the restore happy days if not I will assume it is memory IC problem. Let me know how it goes.
Hope this help
Punteggio 1
4 Commenti:
could a memory IC problem be fixed?
da
Yes you can replace the IC and it should work, but first you have to make sure this is the problem.
da
I restored the phone and its working now. I lost a lot of data, picutures, numbers "/ but at least it works now. Thanks for the help @imimimobile
da
Happy to help. Please do mark my answer as solution for you thanks
da
Same scenario as mine.. :( what will i do???
Punteggio 0
5 Commenti:
Try what I suggest to Jose and see if it work.
da
Hi!
I have the same problem @imimimobile , i dont want to restore the iPhone... if i change the IC Memory, i lost my data anyway?
Sorry for my english
da
Unfortunately if you want to have the phone working you have to wipe it to factory settings. This is the only way to find out if it is software issue.
da
Hi!
@imimimobile I don't care the iPhone, i just want the information back . :/
da
Sorry but if it doesn't connect to itunes you cannot recover the data
da
error 27 is hardware, it sounds weird but worked for me once, heat with a hair dryer the phone for 3 minutes, put it in a zip lock and freeze for 20 !
try again to restore from DFU
try to download a free version wondershare dr phone and hit on restart device.
Punteggio -2
Aggiungi la tua risposta
Jose sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,376
