Salta al contenuto principale
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84 Domande Visualizza tutte
Takes several retries for image to stabilize, logic board not at fault
Weeeeird problem.
Recently, when I would turn on the screen, after a brief flash of the video output, it would go dark. Several retries (switch off and back on) later, it will switch on and stay on for as long as there is power. If it switches off either straight from the power source or the OS settings, I have to do the same thing again.
I followed the troubleshooting guide here and ALL the voltages were correct. I checked all boards for anything suspect and found nothing. So I went ahead and ordered a logic board.
I just replaced the board and guess what? The problem is still the same, exactly.
Is there any chance of repairing this screen without spending more cash than buying an equivalent? (logic board was ~$100 + very expensive international shipping).
Thanks
Georgios
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
I'd try replacing the internal video cable that exits out the back of the display. They are notorious for failing and causing odd video issues like you described.
Punteggio 0
1 Commento:
I'm gonna kill myself if that's the case :) Are there any standard cables I can use for this?
da
Aggiungi la tua risposta
Georgios Diamantopoulos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 82
