Salta al contenuto principale
Released August 22, 2013. Identified by model number NP940X3G.
How can I replace the BA97-03985A touchpad?
Is there a guide how the touchpad (part No BA97-03985A) can be replaced?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The replacement is really simple: just remove the battery (see Samsung ATIV Book 9 Plus Battery Replacement). The touchpad is mounted below the battery with 4 screws (you need a really small phillips screw driver). The spacers (and also the mounting plate) are fixed with adhesive tape and can be removed (by gently pulling) from the old touch unit.
Punteggio 0
Aggiungi la tua risposta
NaVs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 569
