Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone 5 with no screen, How can I check if it works?
I have purchased a second hand iPhone 5 with no screen at all. There is no home button or proximity sensor or earpiece or display. I can see all of the internals including the battery. How can i check if it turns on? I was planning on trying to get a screen for it but I don't want to waste money on a phone that doesn't work and never will work. It looks like the display had been forcefully ripped off of the phone. The ribbon that connects the display to the logic board is snapped and the screws at the bottom of the device have not been taken out.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Unfortunately there is no way to test the phone fully, however plugging it into iTunes should at least establish whether it is dead or not. Visit a local repair shop and ask them if they could try a screen on it for you to test if it still works, most decent repair shops should be willing to help out.
Punteggio 1
Aggiungi la tua risposta
Tom Robertson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 7,037
